Вышла PtokaX 0.4.2.0
Новости мира DC, p2p и др.
Репортёр
Сообщение Репортёр »
Скрипты от 0.4.x ветки должны работать, а вот библиотеки придётся обновить.
Изменения
Added: Missing PtokaX icon to 64bit service binary.
Added: Project files for visual studio 2010.
Added: Crash log generation to new gui windows version.
Added: Core.GetUserValue(tUser, 27) return user MAC Address when it is possible.
Added: Enabled Data Execution Prevention for 32bit windoze version when system support that.
Added: Line numbers to script editor.
Added: Column sorting to registered users list in registered users window.
Added: Filter to registered users window.
Added: Column sorting to ban list in bans window.
Added: Filter to bans window.
Added: Build numbering.
Added: Column sorting to range ban list in range bans window.
Added: Filter to range bans window.
Added: DPI awareness.
Added: Resizeable splitter to Users/Chat and Scripts pages.
Added: Core.BuildNumber returning PtokaX build number to Lua api.
Added: Saving of window sizes, column sizes, checkbox states and splitter positions in gui.
Added: Command line command /generatexmllanguage to generate english language example.
Fixed: Compile with Lua 5.2.0 (beta)
Fixed: Missing user input length checking in some commands (thx Rahim for report).
Fixed: Multiple class member variables not initialized in the constructor.
Fixed: Multiple memory leaks when realloc fails.
Fixed: Multiple obsolete usleep functions replaced with nanosleep.
Fixed: Multiple redundant check for NULL before free/delete.
Fixed: Multiple memory leaks when ip-to-country loading fails.
Fixed: Memory leak when script try to reg bot with nick that already exist.
Fixed: Memory leak when text file creating fails.
Fixed: Integer overflow for temp ban expiring after 03:14:07, January 19, 2038 in 32bit version or 23:59:59, December 31, 3000 in 64bit version (thx Saymon for report).
Changed: Windows GUI, from GUI created with Borland VCL to WinAPI GUI.
Changed: Some min/max setting values.
Changed: Times and dates are now shown in system locale format.
Changed: GUI layout to correctly use system font and DPI settings.
Changed: On windoze memory allocator for Lua is not part of Lua lib anymore, it is now part of PtokaX.
Changed: Default redirect setting and redirect address. Redirect address point to PtokaX alpha test hub.
Improved: Update checking. Now using HTTP 1.1, update file is simple text file instead of xml.
Removed: Setting for send userip to user on login, it is send always when user corretly indicate UserIP2 in supports.
Removed: Setting to popup scripts window on script error, it is obsolete with new GUI.
Rewritten: Resolve code from deprecated gethostbyname to getaddrinfo.
Updated: TinyXML to 2.6.2
Updated: Zlib to 1.2.5.
Patched: Lua with official patch from http://permalink.gmane.org/gmane.comp.l ... eral/76868
SerferInZet
Хаб: dchub://dc.unionbest.org
Сообщение SerferInZet »
Да ну, мне не понравилась. :-(
Sergius`
Хаб: dchub://dc.smolcity.net:1411
Сообщение Sergius` »
да какая разница, нравится не нравится.
главное что-бы работало стабильно! :-)
SergSat
Хаб: dchub://sergsat.ru
Сообщение SergSat »
Итак, не стали работать многие скрипты, ругаются на PXLUA.dll
а также Синтаксис error loading module 'pxsocket' from file 'C:\***\libs\pxsocket.dll':
Не найдена указанная процедура.
Последний раз редактировалось SergSat 27 сен 2011, 06:38, всего редактировалось 1 раз.
Sergius`
собирал пару дней назад на убунте, решил посмотреть :) вообщем все собралось и поставилось на ура, сприпты работают все, только релизы чуть шалят, местами пару строк поменялись...:)
хотя такой косяк был и на 0.4.1.2 поэтому останусь я на старой доброй 0.4.1.1 8-)
Репортёр
SergSat писал(а):Итак, не стали работать многие скрипты, ругаются на PXLUA.dll
Ты читать умеешь?
Репортёр писал(а):Скрипты от 0.4.x ветки должны работать, а вот библиотеки придётся обновить.
SergSat
Сообщение SergSat »
Стоит PXLuaSocket-2.0.2
Сообщение [REAL]AfLc »
Вчера запускал . Библиотеку обновил , всё равно некоторые скрипты сетевые не пашут , например: Курсы валют , кулинарные рецепты в скриптах наверное надо , что-то править. *SCRATCH* + хотел установить птоку как службу.Всё прошло удачно , но когда запускаешь службу , пишет , что не может быть запущена , точно ошибку уже не помню , обратно перешёл на 0.4.1.2.
Последний раз редактировалось [REAL]AfLc 30 сен 2011, 10:42, всего редактировалось 1 раз.
Репортёр
SergSat писал(а):Стоит PXLuaSocket-2.0.2
И поэтому ты считаешь себя в праве не выполнять рекомендации?
[REAL]AfLc писал(а):Библиотеку обновил
А точно? Каким образом ты это сделал?
SergSat
Сообщение SergSat »
как тут написано
Последний раз редактировалось SergSat 06 окт 2011, 10:10, всего редактировалось 1 раз.
Репортёр
И где там выложена указанная тобой библиотека?
absent
Хаб: dchub://general.spb.ru
Сообщение absent »
Синтаксис D:\0.4.2.0\scripts\PXControl_Server.lua
Синтаксис error loading module 'pxlfs' from file 'D:\0.4.2.0\pxlfs.dll':
точка входа в процедуру не найдена в библиотеке DLL PXLUA.dll где брать?
Последний раз редактировалось absent 02 окт 2011, 15:11, всего редактировалось 4 раза.
mariner
Хаб: dchub://dc.klan-hub.ru
Сообщение mariner »
вы когда читать научитесь? чтобы обновить недостаточно бинарник поменять. надо еще и все либы.
SergSat
Сообщение SergSat »
У меня стоят
PXLuaSocket.dll от 09.09.2011
PXMime.dll от 09.09.2011
PXLua.dll от 06.09.2011
а вот pxsocket.dll почему то от 26.01.2008
Репортёр
А Lua-модули для сокетов тоже почему-то от 26.01.2008?
Или старше?
SergSat
Сообщение SergSat »
в папке socket от 15.10.2007
Последний раз редактировалось SergSat 06 окт 2011, 19:59, всего редактировалось 1 раз.
Репортёр
Почему-бы тебе не прочитать ещё раз то, на что ты кинул ссылку? Хотя-бы на пару постов ниже.
ретрАпирдА
Сообщение ретрАпирдА »
неплохая версия. вот только поднаху*вертили разрабы с интерфейсом. лучше бы двигались в сторону интерфейса как у версии 0360. 8-)
наркоман
Сообщение наркоман »
ретрАпирдА писал(а):лучше бы двигались в сторону интерфейса как у версии 0360.
да? А что же в старой версии такого хорошего, что бы им туда двигатсо?? *ROFL*
absent
Сообщение absent »
mariner писал(а):вы когда читать научитесь? чтобы обновить недостаточно бинарник поменять. надо еще и все либы.
как либы менять?
tnesba_ppipesba
Сообщение tnesba_ppipesba »
скачать и скопировать сможешь?? ну это нажать сылку, зарархивировать.. и скопировать в папку libs. архиватор то есть у тебя? :-D
absent
Сообщение absent »
tnesba_ppipesba писал(а):скачать и скопировать сможешь?? ну это нажать сылку, зарархивировать.. и скопировать в папку libs. архиватор то есть у тебя?
где ссылка умник?
tnesba
Сообщение tnesba »
раскрой глаза
SergSat писал(а):как тут написано
anonim
Сообщение anonim »
хз у меня всё работает. я только заменил файл птокакс в папке птохи и всё, остольные папки не менял при обнавлении. всё пашет норм с новым интерфейсом. И также тестил 32-ва бита потоху полностью заменял 64-х битной новой птохой при обнавлении вобще гимор с библиотекой не возникает можно запускать кстати после как и 32-ва бита птоху со старым интерфейсом так и 64-бита с новым интерфейсом потому-что два ярлыка получается в папке но на 64-х битной винде. Тесте пишите свои мнения
megashara
Сообщение megashara »
Обнаружена не совместимось с хаб листами, но а так всё действительно работает на ура! :-)
